Rear suspension kit (no shocks as yet)
Old Oct 17, 2022 | 10:03 AM
redrover41's Avatar
Default Rear suspension kit (no shocks as yet)
Am searching for a complete set of 'hardware' to replace worn OEM rear suspension. Both sides: upper control arms, lower control arms, tie rod links and tie rod itself.
I suppose I should also replace the nuts and bolts that hold everything together. I refuse to pay Jaguar $432.32 for a lower control arm. Any/all suggestions appreciated. I have found sets of lower arms, tie rod links and a few other parts. Should I count on part piecing everything? Thanks in advance to our members.
Old Oct 17, 2022 | 03:06 PM
ctsemicon's Avatar
Remarkably good prices for entire kits, and, Lemforder is good quality stuff.
https://www.berkshirejagcomponents.c...s-c102x2777200
best regards...
Old Oct 18, 2022 | 04:32 AM
Petz's Avatar
Lemförder is whats on it anyway
Old Oct 18, 2022 | 10:51 AM
scooterforever's Avatar
There are a bunch of threads on the compatibility between certain Lincoln rear suspension components and rear X350 suspension components. Pricing on Lincoln-branded versions of the parts is quite good. I recommend searching for those threads. Ford ownership had its benefits re: certain parts availability.
Old Oct 18, 2022 | 07:28 PM
Wingrider's Avatar
2004's can use the lower Ford parts, but the other ones no.
Dave63116
37
Oct 30, 2024 10:21 PM
birch
17
Jul 12, 2021 04:03 PM
annamiata
Jan 1, 2018 04:10 PM
steve_k_xk
May 12, 2016 04:42 AM
