Seeking download sources for JLR-SDD v125 or v130
Old Sep 20, 2019 | 05:09 AM
STRACAT's Avatar
Default Seeking download sources for JLR-SDD v125 or v130
Seeking referral for someone that may have WORKING download software for JLR-SDD v125 or v130....if there is a download link or if I can mail someone a 32GB USB thumbdrive....please let me know......eight 04 nine 4 three 9 nine eight 8.
Does anyone know if the newer app.war is needed for these versions?
Larry Brown
Old Sep 21, 2019 | 09:28 PM
hafren's Avatar
Originally Posted by STRACAT
v130....
FYI
File Type: pdf
Old Sep 22, 2019 | 10:35 AM
motorcarman's Avatar
I sent an INVITE for the MY DRIVE download.
Did you get the files???
bob
Old Sep 23, 2019 | 10:16 AM
STRACAT's Avatar
Default JLR-SDD v130
Yes I did....Thanks very much!!! I still have not got it to work tho....I'm using WIN XP SP2 (32) and I back dated my computer to Aug 2012 and put the Java 6.33 and Adobe for reading PDF's on it...and still no luck. After putting the login username an password it still says fail....I will try to keep troubleshooting it.
Larry
Old Sep 23, 2019 | 01:11 PM
You might try a NEW INSTALL of Windows so NO previous SDD is present.
I had a good old Dell C640 running Windows XP with a NEW XP install and the SDD125 worked fine.
I sold my DrewTech Mongoose to a forum member because I found a Rotunda VCM and I only work on cars that need IDS 118.5.
I also installed IDS 118.5 on another used Dell C640 Win XP laptop and I had no issues.
You can buy used Dell C640 or comparable laptop on eBay with Win XP for under $100.
I keep 2 Dell C640 and a few HDDs with XP in the shop. Cheap insurance if one dies.
bob
Old Dec 3, 2019 | 06:58 PM
alexander thegreat's Avatar
Larry Brown
Hi Larry,
Would you mind sending me the link too pretty please? I could really use the software. No worries if you can't, in any case, thank you in advance.
Old Dec 3, 2019 | 08:45 PM
Originally Posted by alexander thegreat
Hi Larry,
Would you mind sending me the link too pretty please? I could really use the software. No worries if you can't, in any case, thank you in advance.​​​​​​
What software are you looking for??
Old Dec 4, 2019 | 12:57 AM
Oh, I'm sorry for the confusion, I meant JLR version 125 to 130, basically, the versions that doesn't need an internet connection and can deal with 2004 cars.
Thank you.
Old Dec 4, 2019 | 07:48 AM
STRACAT's Avatar
Alexander....yes....I have v125 and v130 and have them both ob different dedicated laptops (and YESSSS they both work)....I saved the files to my hard drive...when I get a chance...I will save them to a google link or I will try to see if I have the link in a thread that was sent to me....I think it was the v130....the v125 was sent as a link also....let me see if I have them
Larry
Old Dec 4, 2019 | 02:35 PM
JoeDredd's Avatar
Or you can run it on a more modern laptop and run xp as a virtual machine on say a Windows 7 laptop. I have done this and it works
Old Oct 12, 2020 | 09:22 AM
Lindgren93's Avatar
Hi Could I to take part of that link, am in need of V125 for my Jaguar x100 (1997). Have V131 but it seems to be too new to be able to communicate with all systems in my car
//Rickard
Old Nov 9, 2020 | 08:48 PM
STRACAT's Avatar
Default Response
did you get what u needed? I’m just now seeing this
stracat
//Rickard
Old Nov 10, 2020 | 01:01 AM
Lindgren93's Avatar
stracat
Hi, unfortunately I have not had any luck in the matter, so if you have it available it would be appreciated
//Regards Rickard
Old Oct 8, 2022 | 04:48 PM
JAGUAR S-TYPE XS TD 2.7L's Avatar
bob
do you still have a copy you are able and willing to share? I am having increasing problems getting at the copy I tried buying from a certain supplier. They seem to have sent it installed on a vm which I am having to try to find a vm player capable of running from my windows XP computer.
Old Oct 9, 2022 | 02:41 AM
nebelfuerst's Avatar
Just 2 cents from my side:
Using VM ( at least with vbox), the SDD does work, but the software for older jags doesn't. ( you'll get a requester in SDD, that it will call the other software and nothing happens.)
This seems to be an issue of using a VM, as it also happens on an image I pulled off a working XP laptop.
Old Oct 9, 2022 | 06:50 AM
My intention is to use the xp laptop I already have, however the obd cable and software supplier, "British Diagnostics" have sent the software contained within an xp vm which I now have to figure out how to get an xp - xp vm player with a current licence and usb functionality to pull off the software from the vm to then copy on to the regular xp on the laptop. Or if I can to preferably download sdd from another source
Old Oct 9, 2022 | 06:51 PM
Wingrider's Avatar
The thumb drive software, from British Diagnostics, was easily downloaded to my computer.
Not by me, but by someone who knows how to program them.
The cable i have, is a genuine Drew Mongoose, not a clone.
Old Oct 26, 2022 | 04:51 PM
Default Where to find the mongoose cable ?
Would you know where to get this cable, genuine of course. I've looked everywhere it's discontinued...
Old Oct 26, 2022 | 07:06 PM
Wingrider's Avatar
Was very lucky when i sourced a new one from Drew, early last year.
Guess there was still one to be found, in the warehouse somewhere
Was not inexpensive though, still $599 + shipping, to my motorcycle shop
They do show up occasionally on ebay.
Saw an older one listed last spring.
Old Sep 5, 2023 | 06:55 AM
KyKa's Avatar
bob
Hello Bob, may I ask to share with me as well?
I’ll need to play around with ECU on my ‘01 X-Type, as far as I understand V130 would be the best option.
Thank You
