Sensor Gearbox
Old Jun 19, 2024 | 10:14 AM
MBolo's Avatar
Default Sensor Gearbox
Welcome back.
WHAT sensor is this in the gearbox where the plug connects to the back? Does anyone know what it is for and what the part number is for the Jag xj350 j8
Old Jun 21, 2024 | 09:28 AM
Big Koshka's Avatar
It is a mechatronics connector. It connects inside electronics to outside. I am not totally sure if gear box ECM is inside or outside of transmission.
To disconnect mechatronics connector you need to turn outside ring of connector CCW. And pull it STRAIGHT out.
​​​​​​there are number of videos on servicing ZHP6, I could quote wrong model here, transmission on U-tube. The same transmission used on BMW, Fords, LR, Mercedes and 'cream' if the crop Hyundai....
Regardless, some different access panels, inside is the same.
Chris Steineger
XK120 XK140 XK150
Jun 29, 2018 04:10 PM
mpsa
XK120 XK140 XK150
Jan 28, 2018 02:25 PM
AlanHiatt
UK & Eire
Apr 12, 2017 11:23 AM
Will R
E type ( XK-E )
Oct 26, 2015 08:22 AM
BigKev
Dec 29, 2012 08:31 AM
