SRS code 17 fixed !
Old Nov 3, 2020 | 02:59 PM
aceler8's Avatar
Default SRS code 17 fixed !
Since i purchased my 2005 XJ about six weeks back, i've had the SRS dash icon flashing. It flashes 1-7 and cycles a few times before remaining lit. After searching and searching, i finally fixed my issue. It's a bit weird, but may help others.
To troubleshoot:
  • get in passenger seat with a slim roll of paper towel roll. All windows in up position - ACC off - Stereo off.
  • turn key to position II:
  • Place towel roll against ear and move to each of the 4 occupancy sensors. There is one in the upper dash next to the passenger seat heater button - one in the A pillar above the dash - one above the B pillar toward the passenger doors - one in the center overheard area of headliner
  • You will/should hear a slight echo from each sensor. I did for 3 of the 4 and found the B pillar sensor quiet
To check:
  • i removed the B pillar trim piece and removed front and rear passenger headliner handles. This gives you room to pull on the headliner for some flexibility.
  • I wiggled the sensor from the roof and pulled through the hole in the headliner and discovered the wire was NOT attached
  • I then moved my hand around above the headliner and found a loose wire. This wire runs from/to the center headliner sensor so they are connected by this wire
  • Odd: the end of this wire had a broken connection...unsure how this could have happened unless the headliner was repaired at some point
To Fix:
  • removed both plastic connectors (since one was broken)
  • removed positive from battery
  • with the smallest wire nuts i have, i ran the wires through the headliner fabric hole to the sensor in my hand and twisted the wires together (black to black & grey to green/yellow) hard to recall the other color, but just make sure black wire to black wire)
  • reinstalled sensor in headliner
  • reconnected battery
  • started car and bingo....SRS air bad light in the dash goes out and stays out
Hope you have similar luck as this was a free fix and costs not much time
Hint: when you reinstall the B pillar liner....move both of the belt adjustments to the lower position - this way they will match up when you reinstall saving you time
Old Nov 3, 2020 | 04:13 PM
Sean W's Avatar
Great news aceler8. Congrats
Ralph12345
Oct 17, 2024 03:29 AM
chrisf
Oct 18, 2019 09:03 PM
Timothy Shaw
Interior
Sep 15, 2019 12:41 PM
jleeto
Feb 14, 2015 12:33 PM
fabfive
May 9, 2011 04:47 PM
