Starting problem
Old Jan 23, 2018 | 06:59 PM
Tomthecarguy's Avatar
Default Starting problem
Started off with the starter just making a clicking sound after sitting in the garage for a couple of months with a retainer on the battery. I cleaned the posts and jumped from another car only to hear the starter strain to turn the motor over. Went and got the big charger with a 200amp boost and the motor would turn slowly and not start. Do I have a fairly new battery gone bad or a starter problem. And why won't it start?
Old Jan 23, 2018 | 07:03 PM
I'm not seeing my car info: 2002 Jaguar xj sport
Old Jan 28, 2018 | 07:31 PM
brian5's Avatar
I would suspect a dead battery first, especially if it's been connected up and sitting for a couple of months. if it's really dead, it will affect any jump start. Try disconnecting it and putting it on an overnight charge, then check the voltage, should be at least 12.5v, or borrow a good battery and try that, a lot easier to swap out a battery than a starter, so worth a try before going down the starter motor route.
GabrielG
Sep 28, 2014 09:15 PM
coolxj8
Jul 29, 2007 12:29 PM
Feb 25, 2007 05:57 AM
XJ40 ( XJ81 )
Sep 20, 2005 04:55 PM
