Thermostat housing for 2004 XJ8
Old Dec 15, 2024 | 09:55 PM
Wtoulan's Avatar
Default Thermostat housing for 2004 XJ8
I'm looking to replace the leaking thermostat housing on a 2004 XJ8 with vin: SAJEA71C84SG11607
I believe the part number is:
AJ89485
I found an aftermarket one on jag bits for like $350. Aside from that there are some cheaper versions on eBay, Amazon, and AliExpress but none from any retailers I really trust. The cheaper ones range in price from $50 - $120. Does anyone know of a decent supplier that makes a good part. The reviews on a lot of these cheaper ones are not good 😅.
Old Dec 16, 2024 | 09:46 AM
Wingrider's Avatar
Have used this vender before;
EBay
ebay.com› str › autohausaz
AutohausAZ | eBay Stores
AutohausAZ is now one of the largest parts warehouses on the Internet, stocking the highest quality OE parts for your car. We're committed to providing you with the most comprehensive service possible with our parts expertise and stellar customer service, as well as our ever-
Old Dec 17, 2024 | 11:55 PM
Bigd675's Avatar
Wtoulan, I have a 2004 xj8 (x350) vin:G14534
and I bought and am using part: Eurospare AJ89485…$125 it’s definitely not as substantial or robust as the original. I’ve been using it the past six months and it seems fine/ok. The electrical connection at temp sensor isn’t right, therefore I reused the original temp sensor. After complete install I had no cabin heat and rising/overheat at engine bay. Stumped for a bit. Took it all apart and found a port wasn’t opened up from manufacturer and drilled it out and once refitted everything functioned normal. A little more details at this thread with pic.
I didn’t see any other reasonably priced options out there
-D-
https://www.jaguarforums.com/forum/x...0/#post2746283
Old Dec 18, 2024 | 12:37 AM
Wtoulan's Avatar
-D-
Thank you!
Old Dec 18, 2024 | 01:32 AM
Bigd675's Avatar
You’re welcome and good luck.
Driftinluke
Apr 21, 2021 07:27 PM
streamsaver
Oct 13, 2018 03:13 PM
slownlo
Nov 5, 2015 05:38 AM
l_duran1
Feb 14, 2014 09:25 AM
jimlombardi
Apr 8, 2011 08:35 PM
