Try this foggy plastic chrome fix...
Old Dec 1, 2013 | 02:58 PM
Mgmagnette's Avatar
Default Try this foggy plastic chrome fix...
Had some of this 3M stuff left over from painting my MG 1100 and figured I couldn't make that plastic chrome look any worse... and bingo! Finally something easy that works!
Old Dec 1, 2013 | 06:15 PM
reyesl's Avatar
Thanks for the tip, will search for that right away..
OK...This better work....
Auto Body Toolmart - Paint Booths, Shop Equipment, Dent Repair Tools
Old Dec 5, 2013 | 09:36 AM
reyesl's Avatar
Recived the 3M stuff yesterday and tried it on the aluminum trim.......did not work. Will have to break-out the power tools and try it again...
Old Dec 5, 2013 | 07:07 PM
Mgmagnette's Avatar
I used a dewalt buffer and the appropriate pad that goes with that stuff... Can imagine doing it by hand. It's machine polish, says it right in the name . If you're being cheap maybe there's a drill mount attachment from harbor freight that will do the trick, good luck!
Old Dec 6, 2013 | 04:25 AM
reyesl's Avatar
Smile
I always start by hand since I didn't want to ruin my paint finish. I have about 7 different types of power polishing machines for different applications as I used to paint cars, trucks, vans, boats, and did metal and wood-working. Will be using one of them today.
Old Dec 6, 2013 | 05:41 AM
Mgmagnette's Avatar
That's a good point. Maybe some blue tape would be in order.
Old Dec 6, 2013 | 10:03 AM
reyesl's Avatar
This has been a very lazy morning, with the snow, ice, sleet, and the fact that I left my VDP parked in the driveway. My cat is now covered in snow and ice (19 degrees F), so I wont be doing any polishing today.
Old Dec 8, 2013 | 09:16 AM
Clamdigger's Avatar
Hmmm, I have perfect-it in my garage, I think it is the only thing I have not tried. So far ATF is the only thing that does the trick. The problem with AFT is that the chrome has to be wiped down with it every time it gets washed or it rains but takes less then 2 minutes..
Old Dec 9, 2013 | 01:48 AM
reyesl's Avatar
I have used just about everything out there and all recommendations from this forum, nothing works on what appears to be aluminum trim but works fine on the ss trim. The only thing left is to make an attempt to remove the plastic covering and polish the bare metal. That is now at the bottom of my to-do-list.
Attached Thumbnails Try this foggy plastic chrome fix...-window-trim-3.jpg   Try this foggy plastic chrome fix...-window-trim-4.jpg
Poet
Feb 7, 2025 02:18 PM
retriever-007
Feb 10, 2017 10:10 PM
adam699
Oct 13, 2015 05:53 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
