Valley Hose
Old Nov 14, 2014 | 02:08 PM
34by151's Avatar
Default Valley Hose
Does anyone have a pic of the fittings
Im looking for a closeup of the fittings themselves
As you all may guess my valley hose is on the way out which is complicated by the fact i'm weeks away from moving house (about 1000km's move) so I cant strip the car down right away and will need to get it transported to my new home
My intention is to replace the hose with an alloy pipe bent to the same shape as the valley hose and use threaded connections at both ends
I could sleeve the ends with a threaded tube and either shrink fit or tig the threaded tube on on (probably both) but Im also looking at tapping the ends and need to know how the hose barbs are connected. Ie are they a press fit or are the cast in ect
34by151
Old Mar 13, 2015 | 04:52 PM
hafren's Avatar
Did you ever get to fabricate a replacement hose? If so I'd be intereted in the specs to accomplish the same. Thanks.
Old Mar 13, 2015 | 10:27 PM
34by151's Avatar
No, in the end it was not the hose that was leaking.
However I will be doing it soon and I will post the details on how it was done
34by151
Pristine97XK8Convertible
Mar 5, 2025 10:32 AM
mikiep
Dec 20, 2019 07:37 PM
inactualis
Oct 2, 2015 11:13 AM
Johncy2000
Oct 2, 2015 01:05 AM
Lubrication
Oct 1, 2015 03:56 AM
