where to get body repaired in Northern VA
Old Dec 27, 2011 | 12:11 PM
Alice's Avatar
Default where to get body repaired in Northern VA
I tried doing a search first, but couldn't find what I'm looking for.
My car was damaged yesterday - the left rear fender is mangled and the left rear light is broken.
Does anyone know a good place to get body work done on Jags here in northern VA?
Old Dec 27, 2011 | 12:44 PM
Brutal's Avatar
If you have an aluminum body 04 and newer you need to call the dealer or jaguar and find out who in the area in certified to do aluminum bodies. It matters and parts are not to be sold to uncertified repair shops...otherwise i cant help you
Old Dec 28, 2011 | 12:58 AM
rudelover2's Avatar
My car was blasted in the passenger side when I got it in 2005 with 900 miles on her. I spliced 2 cars together and got junkyard and dealer parts to make it work at the local body shop. I took a while sourcing aluminum rivets and the body shop had to purchase an aluminum welder. The car has run without a problem since then. Only issue is after 5 years the body filler seperates from the aluminum, and I had that repaired and re-sprayed a while ago. Good as new. 145,000 miles happy. P.S I saved $25,000 after all was said and done
H20boy
Dec 24, 2024 03:23 PM
xjrjag
Oct 24, 2024 03:09 PM
bamforp
Aug 14, 2024 05:36 PM
Rivguy
Dec 4, 2020 07:55 AM
explorer364
Sep 11, 2015 05:44 PM
