My 2004 Jaguar VP XJ8 will not stay started to drive more than a block. For a while it would not start. I give it some time ( which I have found to work in the past) and it started but it cut off once I got on the road. Now it starts every time but trimmers. Has anyone had this issue?
89 Jacobra
close
- Join DateDec 2016
- LocationArkansas
Liked:1,445 Times in 820 Posts
With the limited info given. The first thought that comes to mind, is a plugged fuel filter. Hope thats it. If not give us a little more info to work with, maybe we can help. hope it helps.
Jack
Jack
close
- Join DateDec 2011
- LocationDurham, UK
Liked:17,009 Times in 12,222 Posts
Quote:
Welcome to the forums anngellic,Originally Posted by anngellic
My 2004 Jaguar VP XJ8 will not stay started to drive more than a block. .....
I've moved your question from General Tech Help to X350 forum. Members here with the same model will be able to help.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
JX350
close
- Join DateOct 2018
- LocationCornwall
Liked:70 Times in 60 Posts
Do you have any fault codes present? Is the EML on and is restricted performance showing on the display? Are there any other warning messages showing on the display?
