X350 XJ-R windows dont work when headlights are on
Old May 20, 2019 | 09:17 AM
ljbp's Avatar
Default X350 XJ-R windows dont work when headlights are on
Hi,
I have here a 2004 XJ-R (X350) which a strange electrical problem. I'd really appreciate any help.
The windows only go up/down when the light stalk switch is in OFF position.
If the switch is set to parking lights, low beams or AUTO, the windows won't go up/down.
Based on what I've read here in the forum, these are my attempts so far to no avail:
-tried a different front electrical module, rear electronical module and light stalk switch
-checked the ground points behind the headlights and at the front electrical module
-tried hard reset by shorting ground and power battery cables
-tried disconnecting the interior light dimmer switch, headlights and tail lights
I know the reason why windows won't go up/down is because the output enable signal from front electrical module (pin CR1-14) changes from 12V to 0V when headlights are turned on. But I don't know why this is happening.
Many thanks for any help
Lino
Old May 21, 2019 | 02:42 PM
ljbp's Avatar
Solved!
The wiring for one of the headliner’s light fixtures was shorted to ground (headliner was replaced a few months ago).
Old Oct 20, 2019 | 05:35 AM
Tai Liao's Avatar
Originally Posted by ljbp
Solved!
I have exactly the same issue. can you share what's been replaced or fixed? thanks!
Old Oct 21, 2019 | 04:06 AM
ljbp's Avatar
one of the wires going to a headliner light bulb was shorted to ground, which was causing passenger side fuse F14 to blow.
once the wire was repaired and fuse replaced, everything was ok.
guppy710
Mar 18, 2016 03:27 PM
rjwilson374
May 29, 2015 04:10 PM
Mr_Dobermann
Mar 28, 2011 06:31 PM
sknlz6
Nov 27, 2009 10:17 PM
hafferf
Jun 6, 2009 03:23 PM
