X350 XJR Upper Ball Joint Replacement
Old Sep 23, 2019 | 11:03 AM
-e-l-i-a-s-'s Avatar
Default X350 XJR Upper Ball Joint Replacement
New 2007 XJR owner here and apologies if this has been discussed in other threads, but my front upper ball joints are in need of replacement and the Jaguar dealer is quoting me $700+ for new control arm assemblies. My question is can I replace just the upper ball joints or do I need to go all in and buy new upper control arms with the included ball joints?
Old Sep 23, 2019 | 12:25 PM
XJ8JR's Avatar
Run away from the dealer and find an independent mechanic, if you can't do it yourself. You cannot replace just the balljoint, you must replace the entire arm. There are many aftermarket options available, some for less than $100/pair. The job is not overly complicated but you must remove the shock assemblies in order to remove/replace the arms.
Old Sep 23, 2019 | 02:35 PM
Fraser Mitchell's Avatar
Looking at SNG Barratt, these are priced at $534 !! However looking elsewhere, one can find them for far, far, less, and still the correct Lemforder part
https://www.sngbarratt.com/us/#!/Eng...5/15423/2/10/1
eBay
Old Sep 23, 2019 | 02:48 PM
Panelhead's Avatar
Default Upper control available from Ford.
The Lincoln LS and Ford Thunderbird of that vintage are the same as the XJ part.
I ordered mine from Delray Ford and they were 112.00 each for the Lemforder part.
500.00 for all four. The boots and bushings were all SHOT.
Look on eBay for Lincoln LS UCA of 2003 - 2006 vintage. If a Ford dealer lists them, jump on it.
Old Sep 23, 2019 | 10:20 PM
Thanks for the replies. After searching some other threads, I found the Lemforder part numbers for the Lincoln LS assemblies and ordered them from Rick Auto. Can anyone confirm these are the correct part #s?
Right: Lemforder 3063101
Left: Lemforder 3063201
Old Sep 24, 2019 | 05:21 AM
Panelhead's Avatar
That is the correct part. They are closing them out. The Motorcraft are the same. But 60.00 dollars more. 82.00 is a bargain.
bassmania
Aug 5, 2016 12:38 PM
Shdw2001h
Mar 15, 2016 08:01 AM
hawaiiansurfster
Jan 1, 2013 07:13 AM
Bigvettefreak
Oct 27, 2011 05:44 AM
Goldlion
Aug 18, 2010 12:37 AM
