XFR to X350 CATS Coilover Conversion
Old Dec 4, 2024 | 01:22 PM
  #41
xalty's Avatar
Originally Posted by José Rodrigo Octavio
My car is already a young lady with 22 years, but the air suspension seems to be a bit tired, specially at the eletronic side. During this time I've changed two rear air bags and the air compressor too.
I am thinking about a big change - send the air system away and install a new conventional suspension in her.
I know that many owners did this conversion with success, but what I don't know is about the eletronics.
With the new coil over suspension it will be possible to eliminate those alert signal that appear all the time at the dash instruments?
I understand the the car rides will be good enough for normal use - she is not a racing car.
x350 before 06 model year does not need anything. pull air suspension fuse disconnect battery reconnect and lights are gone
use xf 3.0 diesel shocks if you can find them. v8 na shocks work but are a little stiff
Old Dec 4, 2024 | 01:40 PM
  #42
José Rodrigo Octavio's Avatar
Yes there is a bypass module. Then no dash lights.
You can read about the kit here;
Coil Spring Conversion Kit
Thank you Clubairth1
Renemarcel
Oct 7, 2024 10:20 AM
MeatBag
Jan 28, 2024 10:50 PM
Falfurrias
Apr 14, 2023 02:38 PM
spalmgre
19
Jun 6, 2022 07:50 PM
EsRay
Jan 29, 2018 05:54 PM
