XJ 8 Overheating
Old Jul 22, 2011 | 02:32 PM
louisgar's Avatar
Default XJ 8 Overheating
I just got my 98 xj 8 Jag, and It leaks from the plastick retention tank underneight the front driver headlight assymbly. I just crawled under the car and saw the plastick tank and I see a tube comming out of it. Which looks like a hose should be connected to it. And their isn't. The tube is just there. I don't know if it's missing a hose. I can't really see if the tube has a hole going into the tank or not. CAN SOMEONE HELP ME AND LET ME KNOW IF SOMETHING IS MISSING?
Old Jul 22, 2011 | 09:25 PM
penguin's Avatar
If this is the "coolant reservoir" you're describing then it's possible that the "tube" that has no hose connected to it is the overflow outlet (it doesn't really need a tube, obviously it's better if it's there. It's function is to let excess coolant out in case there is an overfill)
In any case -- how do you know the car is overheating. Are the gauges showing high readings? Please describe all the symptoms (also known as subjective evidence).
mikiep
Dec 20, 2019 07:37 PM
vwbusbits
Oct 13, 2015 03:43 AM
workworkwork
Oct 1, 2015 01:44 AM
bydand
Sep 28, 2015 09:47 AM
bydand
Sep 27, 2015 12:00 PM
