XJ8 Air Suspension Problem
Old Nov 11, 2018 | 02:48 PM
keelak's Avatar
Default XJ8 Air Suspension Problem
I hit something on the highway and it knocked out a small cover piece on the driver side of the bumper and damaged my pump. I replaced the pump and the car rises but now when i open any door it releases air and rides low on the driver side but the left side is still aired up. Please help.
Old Nov 11, 2018 | 03:44 PM
Fraser Mitchell's Avatar
Better if you post this in the X350/X358 forum 2003-2009, where the experts will no doubt examine your problem. Also tell us what fault message you have.
Old Nov 11, 2018 | 04:19 PM
keelak's Avatar
No fault codes are displayed.
Old Nov 11, 2018 | 05:27 PM
I've moved your question from General Tech Help to X350 forum. This is the place to post technical questions about your model.
Old Nov 11, 2018 | 09:59 PM
Brutal's Avatar
I doubt you have a line leaking but you can disconnect and apply vacuum with a handheld vac pump. Sounds more like drivers air spring is leaking. Does it stay aired up with doors closed and only releases when opening????? Thats weird if so
silversurfer1221
27
Sep 27, 2022 02:06 PM
76driver
25
Apr 7, 2021 09:21 PM
BobDev
Feb 21, 2014 10:42 AM
MANIACK
May 30, 2012 09:06 AM
ben824
Jul 30, 2010 01:02 PM
