XJR front brake discs
Old Sep 20, 2008 | 06:13 PM
DonsXJ8's Avatar
Default RE: XJR front brake discs
Are you sure you need new rotors? Before you replace them you should check the minimum thickness, good possibility
that they could simply be resurfaced. For the minimum thickness spec. its usually stamped into the hat area of the brake
rotor itself.
Old Sep 20, 2008 | 06:22 PM
jag_genius's Avatar
i believe i found them before.. i think there the same as stype R's
Forcedair1
Sep 8, 2025 01:57 PM
PMKimpton
Aug 3, 2019 08:22 PM
jdzubas
Oct 4, 2015 09:14 AM
KarimPA
Sep 12, 2015 08:15 AM
pegasus3710
Sep 5, 2015 09:40 AM
