1995 XJ6 new alternator then 1775 code
Old Nov 3, 2009 | 06:55 PM
sparkenzap's Avatar
That code means the transmission has requested the main ECU to turn on the light. You either need to reset ir and see if it happens again, or have someone with the proper software to read the TCU (transmission control module) codes. It is unlikely the alternator change caused this, unless it is only a nuisance code due to disconnecting the battery during the work. I say, get the ECU reset with a standard OBDII scanner, and see what happens. The XJ6 gearbox seldom fails early.
rusty37
Apr 5, 2020 07:40 PM
JimMLiny
Sep 9, 2015 08:13 PM
carcycle
Sep 7, 2015 04:14 AM
jaguarbill
Sep 5, 2015 11:43 AM
