1995XJR question
Old Jun 20, 2023 | 02:08 PM
ormy49's Avatar
Default 1995XJR question
Can the air flow meter LNA1620AA be related or replaced with a after market part?
Old Jun 20, 2023 | 02:54 PM
Parker 7's Avatar
To know if your current one is alive it will read 1.2 volts DC at the proper idle speed , it will increase toward 5 on throttle up
This will be the middle wire of the MAF sensor connector , Green / Pink wire
It is feed 12 volts B + power unlike other engine sensors , Black / Light Green wire , there is a slice in the power feed wire that has the possibility to go bad limiting the current to properly run the MAF
The 3rd wire is a ground , Pink / Slate wire
Old Jun 22, 2023 | 11:33 AM
ormy49's Avatar
Thank you for the information and diagram ,Hopefully I can figure the emissions problem out and keep my car on the road.
Old Jun 22, 2023 | 04:25 PM
Parker 7's Avatar
Check engine light codes ?
Old Jun 22, 2023 | 07:50 PM
Parker 7's Avatar
If you have a emission issue :
remove the exhaust manifold cover and inspect for cracks in the casting , causes rich unburnt mixture
under the car inspect the exhaust manifold donut gasket joint 4 down pointing studs are tight , 13 mm , may even need donut gasket replacement , Part # ?
Before the engine will go into closed loop regulation the coolant must reach 88 C
The instrument gauge is a different sensor and not accurate
See page 78 for the AJ16 SC engine
Codes are on page 111
801S TITLE (jagrepair.com)
With a ELM - 327 you should have :
Short term fuel trim both banks 0 %
Throttle position sensor 13 % at idle
Mass Air Flow at idle 5 grams / sec , there is a common software error
EGR error 0 % , you may not have a EGR in England
Engine coolant temp at least 88 C after warm up , there is a TSB to not rev the engine in a standstill environment and this may also apply to your SC engine version transmission , GM - 80E series
AttyDallas
Apr 30, 2022 08:12 PM
60Gunner
Oct 2, 2021 07:39 PM
BobbyDing
Aug 6, 2021 04:14 PM
cyberlinks
May 25, 2014 09:41 PM
