1996 Jaguar XJ6 Crank no start issue ( camshaft sensor)
Old Jan 14, 2023 | 04:07 PM
kennedie237's Avatar
I do have a reader but the last time I used it for some reason I wasn't able to get any live data. It was just throwing the codes for the o2 sensor. Before I parked the car it was a code for the camshaft.
I am going to try and get more data to see what exactly is going on. But my best shot right now is replacing the fuel pump. I believe it doesn't have enough psi.
Old Jan 14, 2023 | 05:03 PM
Vee's Avatar
Vee
I wish these engines had a port around the fuel rail to connect a pressure gauge to. That would be so useful.
Old Jan 14, 2023 | 06:29 PM
Parker 7's Avatar
I was never able to get fittings to attach a gauge for my fuel pressure , I had to tap a hole into the FPR on the upstream or fwd side as the FPR is installed to see my 43 PSI
I saw somewhere a T fitting to install after I had established mine and have a pic of it on a old broken computer
Something did change on your SLCM with a short time Hard Reset
What I was able to observe with mine is a long time over night reset solves some problems on security system
I was able to see live data with a program I downloaded as a torrent file about 30 cycles but then it required a license key with a purchase
So the free aspect of it went away and someday I will revisit
Try the Hard Reset overnight, can't hurt
Spoiler
Old Jan 15, 2023 | 01:03 PM
Update!!!
Changed the fuel pump and my baby is running! She started right up!!Sad thing is now it doesn't register how much fuel is in it. I put about 6 gallons
Old Jan 15, 2023 | 01:08 PM
xalty's Avatar
new sender is like 50 bucks
takes 5 minutes to replace
Old Jan 15, 2023 | 01:28 PM
Parker 7's Avatar
The fuel level sender has a ground wire with a ground post by the tank area
Researching
The Black / White wire is a sensing voltage B +DC
The Black wire is a car frame ground at point along the outside of the battery area
The ground wire goes into a connector.between the sendor and car frame ground post
Old Jan 15, 2023 | 01:44 PM
I'd like to thank you all for the massive help you've been!! I will post photos when I get her all cleaned up.
​​​​​​Control arm bushings are my next project!
Old Jan 15, 2023 | 01:52 PM
  #28
Parker 7's Avatar
Seeing the RPM indication is a dash of victory.
Old Jan 15, 2023 | 04:36 PM
Would anyone have an idea of what to look for as far as my alarm system goes?
After I started the car that first time I got the beeping back indicating it locked. Now it locks and unlocked, but I don't get the beep?
Old Jan 15, 2023 | 05:40 PM
  #30
Parker 7's Avatar
My need to reprogram the FOB to establish what may have been lost in the short hard reset
Old Jan 15, 2023 | 05:45 PM
  #31
Ahh I have never used the fob. It doesn't work. I'm not sure the Vallet switch works. I just have the key.
Old Jan 15, 2023 | 05:50 PM
  #32
Parker 7's Avatar
There is an overview in this video.at the 6: 30 minute
More instructions are in written text like one of the TSBs
Old Jan 15, 2023 | 06:10 PM
  #33
After watching that video I definitely don't have the red light that used to be on my lock button. But it still locks and unlocks. Maybe a fuse?:
Old Jan 15, 2023 | 06:20 PM
  #34
Parker 7's Avatar
There are 2 basic versions of the security lock control module , one early version has a lot of external relays outside the box and a later version with no relays outside
VIN # ?
FOB frequency ? if you cn find it on the label on the FOB , not always there
There are 2 freqs 335 and 415 hz
Old Jan 15, 2023 | 06:49 PM
  #35
Vin : SAJHX1745TC759440
The frequency on my fob says 315. Excuse the dirt and grime I've never opened the remote since I purchased this vehicle a year ago 🤢:
Old Jan 15, 2023 | 09:13 PM
  #36
Parker 7's Avatar
Not sure that is a Jaguar X300 FOB
Picture from the front ?
Old Jan 15, 2023 | 09:54 PM
  #37
I don't believe it is:
Old Jan 15, 2023 | 10:40 PM
  #38
Parker 7's Avatar
Close but.........................................
I have both a 315 and 433 ( junk yard ****** )
Old Jan 15, 2023 | 10:44 PM
  #39
I imagine that's why it's never worked haha.
I'm going to see if I can get the correct frequency I need and get a proper remote.
Old Jan 15, 2023 | 10:58 PM
  #40
Parker 7's Avatar
They can be very expensive to source.
The junkyard sells them for 5 bucks to a person that sorts them out and resales them.
They will have a bucket of them, or you might find one still in the car as a new arrival.
Leave your name and number at a pick and pull or any savage yard that deals in Jaguars and they will give you a call , just don't sound too excited.
