96 jag vdp vin 7 usa Power steering and radiator questions
Old May 1, 2017 | 07:54 PM
vandenplas408's Avatar
Default 96 jag vdp vin 7 usa Power steering and radiator questions
so im replacing the whole power steering system
on my 96 jag vanden plas vin 7 usa LHD 220k miles on it
I have already received these parts
1996 Jaguar Vanden Plas Power Steering Pressure Hose - W0133-1609096 Eurospare - $75.48
Qty Ordered: 1, Qty Shipped: 1
- Fri 04/28/2017 12:11 AM
1996 Jaguar Vanden Plas Power Steering Return Hose - W0133-1616086 Eurospare - $55.48
1996 Jaguar Vanden Plas Power Steering Return Hose - W0133-1656656 Original Equipment - $75.48
1996 Jaguar Vanden Plas Power Steering Reservoir Line Hose - W0133-1627889 Eurospare - $25.48
AAE 3119V {#M3891ABE} (Remanufactured) Remanufactured; Includes Magna-X Particulate and Magnetic Filter Info
Power steering; Zf W/SENSOR VIN # 720125 On $190
Im ordering today
Genuine Power Steering Reservoir
SKU: W0133-1609579 $143
TRW Tie Rod End - Outer
SKU: W0133-1630438
$27 each
i have to remove my pump and get it rebuilt i guess for $140
i need a radiator ( this car holds power steering fluid in it wtf?)
any ideas on good rebuild services and source for radiator
i was reading the manual says the rack has a locating pin i need to remove and install a plug and washer? where can i buy those?
Old May 2, 2017 | 02:44 PM
found a better pump for $250
Old May 3, 2017 | 12:45 AM
yah $250 for a full pump and drive hog and bell
any one know where i can get radiator
Old May 3, 2017 | 08:04 AM
dagny747's Avatar
Hi, not encourage more expense or work, but I had this down a a couple of years ago and then needed to replace the steering rack as well. I got a rebuilt rack from Coventry West about half the price of a Jaguar one. Also, the PS fluid in the radiator is a cooler below that I found out about when the nut was frozen on and broke.
Old May 3, 2017 | 08:26 AM
Brutal's Avatar
If you need used parts i have been parting out my wrecked 96 vdp. Pm me im getting ready to scrap it so parts going cheap and fast.
Old May 3, 2017 | 08:34 AM
pmd
but still looking for a new radiator as well
Old May 3, 2017 | 09:06 PM
any one know about this locating pin for the steering rack?
my items came in
just need to order the
power steering asembly
radiator
and the whole.power steering will be new
about $1500 in parts
Old May 4, 2017 | 07:38 PM
anyone know about the rack?
Old May 5, 2017 | 09:25 AM
oi bay
Old May 6, 2017 | 09:30 AM
lamee
Old May 6, 2017 | 02:56 PM
well since no one knows about this locating pin for the rack.
ill go to the junkyard and rio one out and see what comes out
Old May 8, 2017 | 06:15 PM
Power steering fluid tpye = Dexron IIE ATF if Dexron III not available
Problem = heavy on both sides ( power steering )
Center pressure low
The manual says to set to Specification. How can i do this?
Lower Column incorrectly set . How can i set to specification?
Stiff or seized steering joint. where can i find a diagram and how to test the joint?
Lower column over extended. how can i set to specification ( maybe same as other>)
How to check and fix free play in the column assembly
where can i get new mounting bolts for the rack it says in the manual i need new ones
Old May 11, 2017 | 11:02 PM
ITEM QTY TOTAL
Jaguar Genuine Part Number JZS100046 | Setscrew 5 $4.25
Jaguar Genuine Part Number XR829166 | O-Ring 5 $23.40
Jaguar Genuine Part Number C2C16681 | Insulator 4 $5.60
Jaguar Genuine Part Number JZP100005 | Clip-Rubber 5 $12.75
Jaguar Genuine Part Number MNA3996AA | Pipe 1 $78.20
Jaguar Genuine Part Number JZB100050 | Bolt-Banjo 1 $16.15
Jaguar Genuine Part Number JWV116001 | Washer-Sealing 1 $9.35
Jaguar Genuine Part Number CBC1400 | Nut-Expanding 1 $0.85
Jaguar Genuine Part Number JZP100016 | Clip-Pipe 5 $12.75
Jaguar Genuine Part Number AGU19441 | Setscrew 1 $0.85
Jaguar Genuine Part Number JHC301220 | Clamp-Hose 3 $2.55
Jaguar Genuine Part Number JHC302230 | Clamp-Hose 2 $3.40
Jaguar Genuine Part Number CAC9294 | Gasket 1 $6.29
Subtotal:
$176.39
Shipping & Handling:
$18.70
Tax (9%):
$15.89
Total: $210.98
man the jag just adds up like a ****
Old May 12, 2017 | 09:39 AM
now i just need
the bolts for the rack to cross member
and KGA24001 i cant find these parts anywhere
Old May 12, 2017 | 09:43 PM
Quantity Item Price Total
MNA4190DB Radiator £458.68 £458.68 Remove
DBC10013 Radiator fan switch £27.16 £27.16 Remove
MNA4241AB Cooling module mounting bush £6.41 £12.82 Remove
UPDATE CART
Subtotal: £498.66
Delivery: £74.53
VAT: N/A
Total: £573.19 aka $762 after fees ect
Old May 12, 2017 | 09:45 PM
close to $1600 on parts ouch
