96 VDP. check engine light codes P1185 P1186 and P1188
Old Jun 16, 2009 | 03:40 AM
sparkenzap's Avatar
Batman:
In the US, you have 4. Two per Bank, fore and aft of the catslytic converter, two banks. They are the heated type and you fault says thatthe heater is not working. I would check the wiring connections, then the sensors. The heater circuits can be tested with an ohmmeter without too much risk of damagie.
Old Mar 24, 2010 | 10:10 PM
sparkenzap's Avatar
Jeff-
The codes say thats what it is whether or not it fixed Batman- Its either a bad sensor, bad wiring harness or HIGHLY UNLIKELY, a bad ecu. Thats pretty muvh it.
Old Mar 24, 2010 | 11:52 PM
panchostatus's Avatar
I'd say bad sensors.
and they're expensive.
BrentGardner
29
Dec 16, 2024 12:13 AM
philwarner
Dec 6, 2021 07:13 AM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
big d
Sep 3, 2015 07:37 PM
daro31
Aug 27, 2015 09:26 AM
