97 X300/Vanden Plas Coolant leak near back of Engine
I am looking for input on what is the cause of a new coolant leak out of the top/back of the Engine behind/near the intake manifold. I can see coolant dripping slowly down the side of the engine and across the starter. There is a heater hose that clamps onto a metal tube that appears to be fitted into the head. I can't see how the tube is fitted into the head, but I believe that this is where the coolant is coming from.
Has anyone seen a leak here before?
There appears to be no access to this coolant tube. Do I have to pull off the whole intake manifold assembly in order to get access to/fix the leak?
Should I try adding stop leak to the coolant? Might this work?
Thanks.
Thanks.
On a though inspection it might be the gaskets of the main engine block coolant loop that has a history of leaking at the tubes along the left side engine block
This would be below the intake manifold
This would be different then the heater core loop
Genuine Water Rail-3.2/4.0 Litre For Jaguar Xj 1995 - 1997 (from 720125 To 812255) Classic | Jaguar Land Rover Classic Parts
mark campbell
04-21-2017 12:52 PM
