'97 XJ6 Electrical Issue
Old Oct 19, 2016 | 10:08 AM
fwinny's Avatar
Default '97 XJ6 Electrical Issue
Hi,
I have a 1997 XJ6 (that I infrequently drive - just use it a few times every few weeks) with the following problem:
After parking the car the driver side rear window (sometime later) went down by itself.
I discovered that a day or two later and it would not go up with the master switch nor the individual switch on the involved door.
I started the car and went for a little ride and it went up - all was fine.
A few days later I came back to the car and the window was down and the battery was dead.
I tried charging the battery but that wouldn't work so I jumped it and it started. The window still would not go up.
I drove the car a bit to charge things up and turned it off and tried it again and it started.
The next morning the battery was dead again.
I took the battery to an auto parts place and they charged it and tested it and reported that it is in good condition.
I put it back in the car and it started but the window would not go up.
I put a "battery tender" on the battery and left it for about 3 days. I just tried to start it and the battery is completely dead again.
I have changed the CPU two times in the last 7 years. The last time was about 3 or 4 years ago.
I'm looking for suggestions on how to proceed?
Thanks,
Ron
Old Oct 19, 2016 | 06:14 PM
95Leaper's Avatar
Intermittent problems are hard to diagnose. Could possibly be a faulty power window switch or a bad BPM. I would first try swapping out the switch with a good used one and see if the problem persists.
Old Oct 21, 2016 | 09:01 AM
countyjag's Avatar
Are you able to measure whether there is any current being drawn from your battery when the key is extracted from the ignition? If you can and there is a current being drawn, start pulling fuses sequentially until you identify the circuit drawing the current, and work back from there.
