AC clutch relay
Old Jun 16, 2014 | 12:49 PM
cygnus x1's Avatar
Default AC clutch relay
Does anyone know the pin out of the AC clutch relay? It is not shown in the JAG x300 (95 XJ6) wiring diagram. I need to test it and the connections in the fuse box.
Old Jun 16, 2014 | 01:55 PM
b1mcp's Avatar
You're right about the 95 diagram. Something obviously went wrong scanning that.
The 96 version shows it clearly. I more often than not use the later versions of the wiring manuals as they are better laid out and I haven't come across anything yet that is different (but I'm sure there is something).
File Type: pdf
Old Jun 17, 2014 | 06:06 AM
cygnus x1's Avatar
Thanks for the file. BTW did you ever have to replace the compressor idler pulley? I was checking everything I could think of and when I tensioned the pulley, it just fell apart. The jag pulley is $70 for a $10 bearing and $2 plastic wheel. You don't want to know what the dealer wants. Most other car pulleys are $15 to $25? Do you know of any aftermarket or other car pulley that fits? I know the bearing ID is 17mm, but I need to know the OD as mine fell apart (somewhere in the 75 to 90mm range)?
hoodun
Nov 20, 2022 02:35 PM
jagent
Jun 5, 2022 02:18 PM
ryan_border
Dec 23, 2015 04:27 PM
dan102877
Sep 29, 2015 06:47 PM
