AJ16 timing chain replacement.
Old Jan 5, 2023 | 06:18 PM
Esprit's Avatar
Default AJ16 timing chain replacement.
Hi All,
I've got my engine stripped and ready to replace the timing chain tensioners and dampers as I had a bit of a resonant rattle at 1200-1800 RPM that I deduced was the timing chains. Now I've got the timing cover off, replacing these is very straightforward.
However, it looks like my primary (lower) tensioner had seized as this is what I found when I got the timing cover off:
How the car was still running right with a chain that loose I don't know!
As a precaution I now want to change the two timing chains as well, which I have, but reading the manual this seems like a pretty involved job calling for specialist tooling to break the oil pump chain and also the need to rotate the engine with the chains off to get to it which sounds suspect, perhaps the procedure assumes that the cylinder heads are removed?
Anybody here done this operation? It really shouldn't be too hard to replace the chains. I have a cam locking-timing tool and can tdc the #1 cylinder as I assume this is the correct position to do this all in. It just seems that needing to remove the oil pump chain before removing the timing chains is a giant fly in the ointment. I'm also assuming to remove the secondary (upper) chain requires the removal of the cam sprockets to get the chain out of the engine?
Can find lots of resources here on replacing the tensioners but very little on replacing the chains themselves.
Any help gratefully received.
Old Jan 5, 2023 | 07:51 PM
xalty's Avatar
Originally Posted by Esprit
Hi All,
YouTube video
i mean you’re not really supposed to be able to get the timing cover off with the head on. obviously with some skills it’s possible oil pump chain looks like a ballache with the special puller
Old Jan 5, 2023 | 09:28 PM
Parker 7's Avatar
See TSB Below
03.1-09 (jagrepair.com)
The upgraded tensioner will have the large arrow cast into the face
See PDF below
Old Jan 6, 2023 | 07:30 AM
countyjag's Avatar
If you have the cam locking tool, you have all you need to do the top chains. Well worth doing given the strip down you have already performed.
I would be inclined to leave the oil pump chain well alone, as it is very well lubricated, and is unlikely to need replacing.
Be careful sliding the timing cover back in to make sure you don’t catch the edge of the head gasket. Ask me how I know…….!
Old Jan 6, 2023 | 12:19 PM
Esprit's Avatar
Yeah the top chain should be possible, do the cam sprockets need to come off the camshafts to do this?
The lower chain can't come off without taking off the oil pump chain though can it?
And yesAnI've already identified the head gasket as the risky part of the reassembly. I plan to get this edge in first and be really gentle tapping the cover back into place.
rockwarrior
F-Pace (X761) / C-X17
Oct 19, 2024 04:00 AM
Andreas Schmieg
May 8, 2021 06:16 PM
ronski
Feb 14, 2013 04:05 AM
TN8Shooter
Sep 30, 2012 09:16 PM
doglegleft2k3
Dec 10, 2010 07:02 PM
