Any connection between ps, pb, and rr abs sensor?
Old Jun 19, 2025 | 01:51 PM
JustSomeGuy's Avatar
Default Any connection between ps, pb, and rr abs sensor?
My power steering isn’t as easy as it should be while maneuvering.
my abs light goes on sometimes.
right rear abs sensor has 0 ohms
could the sensor be causing both problems?
Old Jun 19, 2025 | 03:18 PM
Parker 7's Avatar
Yep ,
Conferring with wiring guide ( Legal Department )
Old Jun 20, 2025 | 04:02 AM
Checking connection under rear seat today.
Old Jun 20, 2025 | 08:36 AM
Parker 7's Avatar
Be careful on dragging seat pan out the door , felt door trim on lower edge
While seat pan out there is a battery cable tie point under a black rectangle plastic cover on the car's right that has the nuts comming loose
Old Jun 20, 2025 | 08:39 AM
Parker 7's Avatar
A good wheel sensor will read 1300 ohms as a basic meter reading
If you spin the tire in car fwd dirrection it will read 1 volt AC , you can compare to the other wheel
Connector has come loose on someone , but your's is a short and not typical fail ( within the sensor ) infinite resistance or open
Have you cleaned the face of the sensor different than connector clean ?
Do not pry too hard to remove sensor , plastic breaks leaving metal cap stuck in hole besides tearing up the internal sensor wires , ask me how I know , there is a trick from Motorcarman ( Bob )
Sensors hard to find and exspencive , but I did find mine on E - bay
Old Jun 20, 2025 | 08:51 AM
Parker 7's Avatar
Old Jun 20, 2025 | 08:56 AM
Parker 7's Avatar
The ABS sensors have 2 sets of 4 part #s during X300 production
They have raised numbers on them but better to check official part list
the set part #s change over on a VIN #
A left will not work on a right , has to do with the target crossing over sensor in correct spin direction
Old Jul 12, 2025 | 05:23 AM
I checked the connector under the seat and rechecked the readings at the ABS connector - they were all similar so I either misread or fixed the that problem.
Landed up resoldering the ABS 12v motor outputs solving the ABS fault.
Still not having any luck with the Servotronic system.
JensenHealey
XJ40 ( XJ81 )
Aug 23, 2022 09:46 PM
brinny
Jun 11, 2022 12:02 AM
swallow_che
XJ40 ( XJ81 )
Oct 28, 2018 11:16 PM
Dave1109971
Sep 30, 2015 11:04 PM
Striker27
Jul 6, 2015 05:58 PM
