Battery drain found - now what?
Old Feb 12, 2018 | 09:56 AM
Lady Penelope's Avatar
RA.Stewart , have you done a hard reset beyond simply removing the positive battery cable only ? This may get your automatic car shutdown sequencing back to normal is it may be out of step . Does your steering wheel extend and tilt manually .
The sound deep in the dash may be the column extend motor turning with the " reach cable " broken which is common . Look for the tilt motor to move the column manually and if not well look at the tilt sensor gumming up and freezing the tilt movement .
Without the column going to full retract and tilt up position the car will not have completed the go to sleep sequence and stay alive draining the battery . The switch on the side of the column ( name ? ) cuts this auto function out . The seats may work out after the hard reset beyond the positive battery cable removing .
The key in / key out command for the go to sleep sequence we'll look at later as it may be intermittent but we'll look at the actuation movement items first for clarity as you can see things visually going on .
Old Feb 14, 2018 | 03:35 PM
ra.stewart's Avatar
Yes, I have done a hard reset (assuming you mean grounding the positive cable). The column moves manually with the switch and the sound I hear appears to be tied into the ventilation system. I sprayed the ignition switch little "flap", that appears to be the trigger for the switch and the key in gong and left your lights on gong started working. Lately you only got the singular ding....ding....ding, but now get both that and the dingdingding if that makes any sense. I put a fresh fully charged battery in it and will not have a chance to do anything until Saturday, so I think that alone will be a pretty good test all by itself. We love the car but it certainly has its idiosyncrasies! The previous owners told us "you just have to let her do what she wants to do" when it comes to automatic adjustments, etc.
Old Feb 14, 2018 | 03:41 PM
In order to enjoy physics , it first must be obeyed .
Lube the dingdingding thing a ma jiggy and try with a full battery of 12.77 volts .
Old Feb 21, 2018 | 04:45 PM
ra.stewart's Avatar
Well that did it! Tried it Saturday and she kicked off perfect. Didn't get a chance to run her again until this afternoon and she kicked off perfect again. Thanks for the tip and diagnostic advice.
Old Feb 27, 2018 | 11:59 PM
xjfourty's Avatar
Originally Posted by ra.stewart
Hi, I'm having a similar draw problem and have these symptoms, anybody have some direction for me? It is a 96 X300, the automatic memory function stopped working years ago but if you touch one of the buttons everything works. If I take the key out the column does not move, but if I have it in the aux position, press a memory button it will move and if I turn it to off it will continue to move. If I remove the key in the middle of the movement it stops immediately, so I'm thinking the switch is functioning. When I put the key in or take it out there is the sound of a motor running but it is not the column motor, it sounds like it is buried a bit deeper behind the dash.
Another symptom is it sometimes does not unlock the doors when you turn the car off and seems to want to keep you in the car. I did replace the security module a couple of years ago when that system went haywire.
Driving rain here today or I would be pulling fuses, etc. but I've got a feeling this is something along the lines of a hung relay or switch somewhere.
Thanks in advance for any suggestions!
I have all your symptoms. On my 96 x300 when I switch the engine off, the doors stay locked. They open only when I engage the door lever from inside to go out. I thought it was normal. But now from you I learn the doors should be unlocked when you turn off the engine and remove the key.
Old Mar 7, 2018 | 07:26 PM
ra.stewart's Avatar
I quick squirt of WD-40 seems to have cured my troubles, give it a try.
