Beeping 'alarm' when I remove key from ignition (not transmission)
Old Oct 22, 2024 | 05:20 AM
b1mcp's Avatar
The system is very sensitive to resistance (oxidation/dirt) on the connectors. A fault is flagged if the total resistance on the Air Bag is more than 4 ohms. I have seen faults clear permanently just by unplugging and plugging in again.
I suggest first step is to use contact cleaner on the connectors as that may be all that is needed now.
Old Oct 22, 2024 | 06:45 PM
Parker 7's Avatar
You have 4 black box devices between the headlight pairs , 2 for headlight current sensors ( light inoperative dash light ) and the yellow conduit for the crash sensors , while you are there , spray some WD - 40 in the horns and not a penetrating spray as you want to leave a lubricant behind for the air driven horn
Yep , some digging to do
delhump
Mar 28, 2023 02:26 AM
IXLLER8
Dec 27, 2017 06:48 AM
beleive
Dec 8, 2016 01:52 PM
cvcstudios
Sep 23, 2014 05:13 PM
