Brakes do not release
Old Sep 15, 2023 | 08:04 PM
BBB's Avatar
BBB
Post Brakes do not release
Today when I applied the brake pedal, it would not release, the pedal remained down. The brakes were totally engaged and had to drive to a local shop (1/4 km) at full power. The shop is not familiar with 1995 Jaguar XJR Canadian Model. Does anyone have any suggestions?
Old Sep 15, 2023 | 10:31 PM
xalty's Avatar
booster or the pushrod got stuck on something
Old Sep 15, 2023 | 11:21 PM
Parker 7's Avatar
To roll the vehicle I would stay away from removing a fliud brake line least the later complications of properly bleeding the brake lines and if the shop can restore no air in brake lines
You might remove the vacuum hose from the booster and see if it lightens up on the brake force for small shop movements but not road ready or safe
You would have to insert a bolt in the open hose end least a small engine regulation caused by a vacuum leak
The proper brake system bleeding procedure will be coming later as a PDF or someone can walk you through it with the complications of the anti - skid module
Old Sep 15, 2023 | 11:45 PM
Parker 7's Avatar
See section 12 in PDF below
Bleeding instructions section 12 . 4
nickdabs
Oct 30, 2017 06:14 PM
Sid's XF
Nov 5, 2014 05:03 PM
Jag Po'
Jul 26, 2010 07:58 AM
inertian
Jun 4, 2009 09:04 PM
