cooler fans
Old Sep 20, 2015 | 09:24 PM
19jag95's Avatar
Default cooler fans
All of a sudden my radiator cooler fans stay on. Neighbors knock on the door to see if I knew. The only way to get them to shut off is to disconnect the battery. How do I solve this problem.
Old Sep 21, 2015 | 12:01 PM
BigBossRadio's Avatar
Default Check Fuse
The cooler fans have 2 fuses located in the engine compartment LHS front fuse box. Fuse #11 and Fuse #17.
I had a similar problem in the past where the cooler fans continued to run long after turning off the ignition. I removed the fuses and replaced and it fixed the problem.
Please note the the fans are designed to continue running for a period of time after turning off the ignition, this is normal
I hope this helps.
Old Sep 21, 2015 | 12:08 PM
Default Check this thread out
You should also read this thread for more info too
https://www.jaguarforums.com/forum/x...uously-149791/
Old Sep 21, 2015 | 12:09 PM
cool's Avatar
change thermo switch DBC 10013 its located at the very left bottom of your radiator facing the engine.
Seth
Nov 1, 2015 12:17 PM
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
workworkwork
Oct 1, 2015 01:44 AM
Vector
US Lower Atlantic
Sep 28, 2015 11:08 AM
