Dial lights - illumination control module?
Old May 10, 2014 | 06:24 AM
gj1982's Avatar
Default Dial lights - illumination control module?
Hi all
Another little niggle - the dial lights in the dash of of my sovereign are on all the time as soon as the ignition is engaged. I can't turn them off at all - I've clicked the dimmer on the steering column but it's had no effect. I've read that it may be a lighting control module issue?
Could anyone tell me where exactly this module is and how to remove/replace?
Also, when driving I've noticed a few clicks from around the steering column - clicks that sound very much like the one from the j gate when you press the brake. Anyone know what this might be?
Many thanks!
Old May 11, 2014 | 06:08 PM
sogood's Avatar
The light control module for the dash lights is fitted under the stering column shroud, at the side, on the side facing the passenger seat. It is a small black plastic box, about the size of a matchbox or slightly smaller and is a known fail item. It may well be held in place with a nylon tie. There is coverage of this on Jaglovers in a thread by jim butterworth if it helps.
H20boy
Dec 24, 2024 03:23 PM
Jpav27
Jul 31, 2022 06:43 AM
XJsc-guy
Sep 25, 2015 11:09 AM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
jaguarbill
Sep 5, 2015 11:43 AM
