DIY Modification to Improve Performance and Fuel Economy of AJ16 and AJ6 Engines
Dear All,
The latest batch of brackets are nearly all gone. There are only 2 left. If anyone wants one, then please get in touch. andystodart@metronet.co.uk
I ship the brackets worldwide from the UK. I'm now currently out of stock, but the next batch should be ready on 4th October, if you want to order one. This new batch of brackets will fit all Jaguar AJ16 engines, including those fitted to the XJR6 (95-97MY)
Nighteyez
may I humbly recommend combining Andy's bracket with a pod filter to maximize the benefit?
I convinced a 68 mm K&N pod to fit, (I bought the filter on a whim before I had a chance to properly measure the diameter of the plastic pipe behind the airbox), but the appropriate diameter is 75-76 mm. It opens up the top end and with the advanced spark timing, the AJ16 gets a new lease of life...and this is only on the 'baby' 3.2
Pod filter looks like the link below
it is sort of cylindrical often with an inner surface too, so has a bigger surface area.
there are replacement panel (flat) filters but in my experience with 2 previous non-Jag cars not worth it - same surface area, same restrictive air box.
The pods give a bit more intake noise, but not excessive on my 3.2 and I like the sound. Worth turning the stereo off to hear it..
K&N Universal Clamp-on Air Filters for a Variety of Universal Air Filter Applications
Will have to wait on getting mine installed, took a 2 day trip down the coast, and ran over something that put a hole in the oil pan.
So when that is replaced, I will have the bracket installed.
Jim
So when that is replaced, I will have the bracket installed.Jim
I emailed you regarding the bracket. Suppose you have none left from last order? If not, I would like to put in my humble request for one when another order come round. Thanks!
Where I live improved acceleration and speed is not that important. Fuel mileage IS. In rural East Texas everything is a long way off unlike what it is in UK. So, what mileage improvement am I likely to see? Right now with the 95 4.O I get around 26 mpg highway at 70 mph.
