electrical problem
Old Aug 3, 2009 | 10:41 PM
cooke's Avatar
Unhappy electrical problem
Every now and then different indicator lights come on for no reason at all. Yesterday the airbag light came on in the dash board when I started it up. Do x300's have a wiring harness problem? If the answer is yes does anyone know what to do about it.
Old Aug 3, 2009 | 10:46 PM
JagtechOhio's Avatar
Minor and random faults, nothing like inherent faults with the wiring harnesses. A proper code reader will retrieve stored codes from you car's electronic control modules to help identify the reason that the lights came on. In the case of an intermittant air bag warning light on an X300, the GUESS would be a bad casette reel: that's the contact ring behind the steering wheel for the electical connections to the driver's air bag.
Old Aug 3, 2009 | 11:45 PM
cooke's Avatar
JTO thax for your quick response. Where would I find a code reader and what kind am I looking for?
Old Aug 4, 2009 | 12:26 AM
You're welcomed, Cooke.
The problem with code readers is that some will get you a little, few will get you alot.
A generic code reader like a $50.00 Actron will read common engine performance codes that will help lead you in the right direction when troubleshooting.
The airbag system requires a scanner that reads body codes: to my knowledge, the cheapest route means purchasing AutoEnginuity software and hardware to interface with the car and read codes on your laptop. I have not used this system, and I have read on this and other forums that it is not fully compatable and as a result, not fully effective as a diagnostic tool.
Which leaves WDS and IDS, and that is the Jaguar proprietary diagnostic system and its more comtemporary replacement. You can't handle it.
Best advise is the cheap scanner for the simple stuff, dealer for the rest. None of this stuff is easy to diagnose, and complete and accurate technical information is not easy to find. When I first started trying to figure out what tool I needed (I use WDS), there wasn't even a description to be found like the one I just wrote you.
You don't have a bad car, there are just a few minor and/ or intermittant problems to straighten out. A few you may be able to tackle yourself, a few you won't.
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
mbergen
Oct 23, 2019 10:26 PM
jdzubas
Oct 4, 2015 09:14 AM
mcdutch
Sep 4, 2015 03:38 AM
