Engine stops, and starter will not work.
Old Apr 6, 2026 | 11:13 AM
NorwegianXJR's Avatar
Default Engine stops, and starter will not work.
Today, I was going to get my XJR from winter storage. It starts emidiately, but after about one minute it stops just like the ignition was turned off.
After that, the starter was not working at all, not eaven a click in the relay. Everything else in the car seems OK, and the battery is almost new an fully charged.
I was thinking about bad ground, and got a very thick jumper cable from the ground on the battery, straight to the engine. Just the same: Nothing happened.
Anybody who have a suggestion for what could be wrong.
The car had some issues last summer also, with suddenly turning off some times. The ECU is just returned from refurbishing in a proffesional carelectric workshop.
Old Apr 6, 2026 | 12:57 PM
Parker 7's Avatar
Questionable work on the ECU ?
For the starter there is an enable through the engine ECU so look to be powered at all times by the 2 ECU power sources , right engine bay fuse box relay in the corner ( # 9 ) and the large # 5 right ECU controlled relay , this relay is controlled by the ECU and brings high current power back into ECU
small relay swap with the left engine bay fuse box relay in corner , only runs car horn
large relay swap with the headlights , fog , or A / C clutch of the same part # but in this case the relay is controlled by the ECU so to take that out of equation jumper the relay socket 3 to 5
These large relays can be easily be in wrong mounting position
Your starter relay not clicking splits your starter circuit in half pointing to the enables which your BPM sums up and provides a ground to close the starter relay
Old Apr 6, 2026 | 01:08 PM
Parker 7's Avatar
The starter sequence as it relates to the ignition switch which must have a good car frame ground on pin 5 of the IG switch connector
IG switch will give a ground path ( through pin 5 ) to close the right engine bay fuse box relay in the corner ( labeled as ignition positive relay ) , this first ECU power provides an enable for starter motor
IG switch will give a spring-loaded momentary ground path through pin 5 as a starter enable / command , this is your primary starter command asking BPM if it has the enables ( ECU , security , trans position and such )
The car side of the connector lifts straight up to remove from dash to bring work out to you , in your case no need to remove key barrel and if removable IG switch from barrel needing replacement no new key needed
Nap time
Old Apr 6, 2026 | 01:24 PM
Thank you. I will check the relays and fuses tomorrow
Old Apr 6, 2026 | 01:31 PM
Parker 7's Avatar
This is your starter circuit for your engine / GM transmission combo like the V - 12
Old Apr 6, 2026 | 05:22 PM
Thank you very much.
Ozzo
Jul 29, 2024 01:13 AM
Parker 7
Aug 28, 2021 01:12 AM
jimbo61
Oct 5, 2019 05:03 AM
evildrome
Aug 13, 2018 10:28 AM
kobe3006
Sep 9, 2012 06:19 PM
