Exhaust Manifold Repair
I found replacement downpipe studs ( 4 totoal ) at Welch Jaguar Parts out of Ohio real cheap and quick
Tried the large and small hardware store bins of 20 different stud sizes to no avail
That threading of the 2 small solid lines into the sides of the exhaust manifold got me , so may want to start them in free air before moving exhaust 2 castings into their position
True on the cooling of the ignition coils
California has a different engine ECU that may tweek the exhaust products for their emissions , at least on the TSB 493 EGR upgrading including the replacing upgraded PROMS ( data array maps )
From old school thought , the proper way to set up for crack welding is to build a heavy and I mean boiler plate fixture and bolt on manifolds , Place whole bolted on fixture in a preheating oven then weld , the cool down procedure is to place back in oven
Now the challenge is finding someone that does that procedure
The yard I pull parts from has a X300 that may have downpipes , only visual if they are or not cracked
sunchip
Aug 28, 2023 09:21 PM
Mclovin22
Aug 14, 2022 12:22 PM
