Front shock bushing assembly order
Old Feb 24, 2016 | 11:16 PM
1997Sovereign's Avatar
Default Front shock bushing assembly order
Somebody has already replaced the front upper shock bushings,but is kinda does not look right.
Top of the shock is the steal #1 washer-#2rubber bushing-#3steal washer,the bolt goes through the shock tower then it is another rubber bushing then washer then the nut.
Is that the correct order? Most I have installed before was where the rubber bushing was bottom of the shock tower then the top rubber and steal washer under the nut. Confusing?
Old Feb 25, 2016 | 02:27 AM
b1mcp's Avatar
Here's a link to the parts diagram for the front shock which will probably help.
Road Spring and Damper-Front - Parts For XJ Series from (V)720125 to (V)812255 (X300) | Jaguar Heritage Parts UK
Old Feb 29, 2016 | 09:28 PM
Thank you for that,it was assembled wrong and enlarged the shock tower hole,made groves in different directions.
I put it back together and aligned it the best I could eye up and will see how it holds.
DannyG
May 19, 2016 11:42 AM
Skarre
Apr 17, 2016 02:55 PM
adenshillito
Feb 24, 2016 10:14 AM
hawaiianjag
Feb 22, 2016 05:49 PM
PeteK812
Feb 22, 2016 03:08 PM
