Fueling questions
Old Apr 17, 2020 | 10:54 PM
PunkLegacy's Avatar
Default Fueling questions
I'm thinking about replacing my fuel pump and injectors in the near future. If I upgrade to a walbro 255 and the xjr6 bigger injectors in my na car would I need to get a new ecu or find some way of tuning? I'm not trying to add a lot of hp but if I'm gonna replace something I figure I might as well try to upgrade it anyway.
Old May 10, 2020 | 01:20 AM
Parker 2's Avatar
The power of the engine is limited to the maps or data arrays in the stock ECU
The o2 sensors determain the output gasses to make the ECU calculate the amount of fuel to inject into the cylinders
The ECU has a " target " left over O2 level after cylinder combustion that is different then a optimal fuel/air ratio for the other combustion gasses like nitrates
This is called short term fuel trim and the ECU constantly adjust the cylinder fuel charge * pulsewidth or time ) to maintain this target and is assigned the value of 0.0
By putting in a higher capacity fuel pump or injectors the ECU will adjust the injectors pulsewitth to put out your original power and not go to a rich mixture ( positive STFT )
If you increase the mass air flow into the cylinders the ECU will adjust up to a certain design point ​​​​​​a new pulsewidth for a larger fuel charge into the cylinders .
You can extract more mechanical power ( work ) from the expanding cylinder combustion gasses in the present setup with a Andy Bracket which biases the ignition timing before top dead center
Kwik Kat
General Tech Help
Feb 28, 2020 01:44 AM
benji808
Oct 4, 2018 10:22 AM
tommy1394
16
Apr 28, 2018 04:07 PM
hlw
Nov 28, 2015 06:09 PM
Ixlr8
May 22, 2011 08:19 PM
