Gearbox light, idle problems
Old Jan 22, 2022 | 03:03 PM
  #61
Parker 7's Avatar
If the ECU sees a sensor out of expected range it will disregard the sensor and default to a less then optimal set of data maps to regulate the engine
The moment this accurse has a time dampening component to it
Since the MAF is never in range it may already be in default
An example would be a open spot on your TPS sweep
Not saying you have one
Old Jan 22, 2022 | 03:16 PM
  #62
Alejandro_Montijo's Avatar
To do list
1 check the MAF voltage, clean it
2 check the gap on the butterfly throttle not release the TPS.
Old Jan 22, 2022 | 04:09 PM
  #63
Parker 7's Avatar
Check the part #s of the MAF and ECU to be sure you are working with the correct parts
Clean the O2 sensor connectors and grounds
Inspect the Papa Indy 1 and 61 connectors
Did you remove and clean the transmission casting body connector underneath ?
Old Jan 23, 2022 | 02:38 AM
  #64
All MAF and ECU connectors are okay
O2 sensors are okay but one of them has a lower reading at idle. I will change the positions to inspect an injector issue...
Papa Andy was okay too.
I release the gear box cover on the radio side... It was clean too. The main conector on the lower part from the gear box, could be on the my to do list, cause I cannot access easily to clean it. I will try it today.
thanks
Old Jan 23, 2022 | 10:53 AM
  #65
Parker 7's Avatar
Since you have the GM transmission the transmission connector is different
The connector on the normal transmission can be gotten to without jacking the car
ECU and MAF part #s ?
I found green corrosion on my rear O2 sensor connectors
One way to measure the final performance of the full throttled supercharged engine is to run a wire into the cabin from the middle wire on the MAF
The voltage reading can be compared to someone in New Zealand that had restricted and limiting throttle movement until he resolved it
His results were in the 5 volt DC range
Old Jan 23, 2022 | 11:18 AM
  #66
Yes , the supercharged MAF is a different part # then the normally asperated
The MAF and ECU are different for the SC
Even with the values you read on the MAF multiply by 10 or 100 to make more sense , software error in the device
At the correct idle speed the MAF on the middle wire should read 1.2 volts DC on paper
You can adjust it to match the current idle speed up a bit
Middle to line cable
The both sides cables
The MAF is clean
Is there something wrong?
Old Jan 23, 2022 | 12:12 PM
  #67
Parker 7's Avatar
The MAF is powered not by a reference voltage of 5.0 DC ( like the other sensors ) but I think without looking 12 volts or B + whatever that may be
The connector has to be hooked up to power the MAF and you are looking for the return signal back to the ECU
Researching
Old Jan 23, 2022 | 12:26 PM
  #68
Parker 7's Avatar
Green / Pink wire with the engine running and everything installed including ducting . 1.2 volts DC at idle
The MAF is powered by B + voltage on the Black / Light Green wire
Old Jan 25, 2022 | 02:50 PM
  #69
so my MAF sensor, it's okay (12 battery)
Old Jan 25, 2022 | 03:04 PM
  #70
I have notice a poor wiring on the knock sensor but I release the cable and try to start the engine and there was no issues or fouls codes at the OBD readings...
The power wiring is because there was a 150 ohms resistor...
Also it was only one orange-grey cable as showed on the picture.
That is the knock sensor B
Aj16 MY1994 November
thanks all
Old Jan 25, 2022 | 03:10 PM
  #71
Parker 7's Avatar
It is the return voltage of one point two that is important that the ECU uses and not the twelve the MAF is powered by
middle wire
The one point two will increase with increasing throttle
Old Jan 25, 2022 | 03:45 PM
  #72
Parker 7's Avatar
The knock sensor if the ECU sees it as triggered will retard the ignition timing and reduce performance
The first generation ECU may not show a fault code because this ECU didn't have all the bugs worked out yet
You might be able to see that your timing is at 25 degree advanced and I think this is correct
Old Jan 25, 2022 | 04:47 PM
  #73
My timing is about 17-18°
Fist engine revs Third timing... 17°
And what about the resistor? Is it usual or have I to deleted it?
thanks
Old Jan 25, 2022 | 05:05 PM
  #74
Parker 7's Avatar
At higher RPMs the timing will be more advanced and you may see 25
The timing also relates to the throttle position compared to a mass air flow and RPM if it is behind
Old Jan 26, 2022 | 04:30 PM
  #75
Today I have checked the spring butterfly and it is okay. It can close the throttle butterfly easily (I contó close it more than the spring...) it estoy at the idle screw.
This is how it looks like. The spring is okay and also the idle screw...
Next step IAC release and check...
Old Jan 26, 2022 | 11:57 PM
  #76
Parker 7's Avatar
Unless the throttle pedal has a return spring something has to drag the cable through the cable sleeve to return to the idle stop
Hard to tell if the updated stronger spiral spring is installed but a 2nd external straight spring can be add as a test to see if it give you the idle results
but you did say by twisting your hand you are already at the idle stop
Yes the IAC valve , but is recommended to put some heat on the inside of the TB in the IAC bolt tread area least they break off
Remember to leave the TPS alone for now
Electrically you can test the windings on the IAC step motor
This would be before risking bolt breakage
You may not see a open winding until it is warmed up or hit with a screwdriver handle on the side
You have 4 to the square power combinations or 16
but green to red is electrically equivalent in looking for a open regardless of polarity as red to green and so on
So you have 9 different combinations
ECU black connector
Old Jan 27, 2022 | 10:43 AM
  #77
There is no problem with unscrewing the IAC I had removed easily a few moths ago.
I will compare the connectors with an other IAC that I bought and the patterns screw was different . May be I will adapt it to the throttle body in other to see what happens... let's see...
thanks
Old Jan 27, 2022 | 05:29 PM
  #78
thanks
The IAC has around 50 ohms resistor between their pins so it's okay.
the thing is that the cone rail is out as you could see on the pictures below
The IAC I think it's okay but may this could be not okay and the dual rail are required to stop the cone spinning.
Old Jan 27, 2022 | 06:07 PM
  #79
Parker 7's Avatar
Ignition coils ?
Old Jan 28, 2022 | 12:06 AM
  #80
Ignition coils ?
I will check the sparks quality with specifics tool to see the coil conditions.
so is the IAC ok taking in account that the cone scree could be screw and unscrew freely be itself?
