Headlamp replacement
Old Dec 15, 2017 | 02:36 AM
Sceleton's Avatar
Default Headlamp replacement
Hello,
I have to replace part JLM12413
https://www.jaguarclassicparts.com/uk/part/JLM12413
Are you able to help me how to do it properly (do you have any pdf file with instruction etc?) to don't brake anything?
Thank you in advance!
Old Dec 15, 2017 | 02:49 AM
Lady Penelope's Avatar
For the price as a new single lens have you considered relapsing all 4 with the used X308 lenses from the scrapper which are much brighter ( appearance not light performance ) and cleaner . You will need the plastic base ( item not numbered in pic ) behind the lens rear silver reflector dish that it snaps into . Different bulbs ?
Look at your orientation as the " V " brand lettering is up . Spray some penetrating oil on the 3 release palls and let soak overnight as they get stuck and you don't want to break them without doing this . Use a long screwdriver to pry them off in that small recess where to 2 pieces meet . If you get the 2 top palls off the bottom one can be popped off by hand but is preferred to use the long screwdriver on that bottom one as the whole mounting base can break , old plastic . The chrome rim must be oriented as well with the use of a piece of tape maker . The filler between the 2 inboard and out board lens assemblies can be removed .
Old Dec 15, 2017 | 04:03 AM
Sceleton's Avatar
thx, I had chance to buy one for really low price 40USD, I had wrong one (UK version) and I have to replace to EU one. I will try to do it like you wrote thx
Old Dec 15, 2017 | 12:15 PM
The inboard and outboard lens assembies are different and someone mentioned left side and right also . Not aware of the UK difference .
Old Dec 16, 2017 | 08:14 AM
Sceleton's Avatar
It was easy I used WD40 to oil them a little, removed metal cover + plastik part of grill then used my hands to remove it from these plastic holders and done
frsing
May 29, 2017 10:16 PM
danimo
Feb 29, 2012 09:06 PM
bulkmail07
Sep 28, 2011 11:59 AM
thisheregirafFe
Jan 21, 2010 08:53 AM
MustangSix
Jan 9, 2009 03:28 PM
