Headlights question
Old Aug 27, 2018 | 03:12 AM
kingnero's Avatar
Default Headlights question
I recently had a headlight go out, catched it right away due to the indicator light on the dash.
However, after replacing the bulb, the indicator light won't go out. How do I do this?
another question: came across an XJ 6 with these headlights: Are these original? common modification? do they give better visibility/are they much brighter?
Old Aug 27, 2018 | 08:01 AM
Richardhw's Avatar
I don't get a bulb failure warning on the dash when one of my headlights goes out but I do if a different bulb does so in my case I would check all the others, I don't know if that is how it should be or if it's a fault with mine.
On the other question, those are headlights from an X308, it's a common mod and quite easy to do with some slight changes to the wiring connection. Very worthwhile doing, the lights are much better.
Old Aug 27, 2018 | 09:36 AM
Lady Penelope's Avatar
The current senorsare ;ocated by the 2 horns beind the front center grill .Do a slight tug on you splices .
Old Aug 28, 2018 | 02:21 AM
SleekJag12's Avatar
The dash indicator should go off when all the bulbs are working. I believe in the last exciting thread on the subject it was discovered that even the license plate (number plate) lamps are sensed in the bulb circuit.
I can't really commit to liking the "look" of the X308 headlights. Personal taste. But I would agree the standard X300 headlights are not as effective as I would like.
Old Aug 28, 2018 | 04:48 AM
katar83's Avatar
Difference between X300 and X308 headlights are day and night, I often considered X300 headlights to be completely inadequate to driving at night or even dangerous, especially after 20 years of collecting dust and dirt.
Upgrade to XJ8 lights is by far the best thing you can do to your car and I can highly recommend it.
jagxkrtoofast
Aug 30, 2018 02:14 PM
Goncalo Proenca
Oct 20, 2015 04:52 PM
mickjaguar
Dec 10, 2014 06:27 AM
temokk
Mar 22, 2011 02:06 PM
MRPAL
Sep 7, 2007 03:12 AM
