To high rpm in N & P
Hallo !
Today i fitted my rebuild Supercharger and lower pulley and new oxygen sensors ( orig ). I also cleaned the Tb and installed a new bypassvalve and the underpreassure component. Also new sparkplugs installed.
But i have now the same high rpm in Parking and neutral gear as before. 1400-1500rpm. When i shift in drive then i have got about 800rpm. Anyone knows the reason for that problem ?
Hallo !
The pin is part of the IACV. The stepper motor controls the pin to determine how much are is allowed to bypass the throttle butterfly to keep a steady idle
So i drove the car now for 2 days it runs perfect but the high rpms in P & N sucks !
I need new brakes when the mechanic cant solve the Problem. I told him about the IACV and he told me he will clean it and adjust it . I hope it helps.
Have your EGR service or replace, there is a recall on that part, that is one of the major part that controls the RPM too.
