Interpreting O2 sensor readings...
Old Aug 23, 2013 | 03:31 AM
Ziggy's Avatar
Default Interpreting O2 sensor readings...
Hopefully a quick one - what's the voltage range on the lambda sensors fitted to our cars & what's lean vs rich etc.? Thanks!
Old Aug 25, 2013 | 05:13 AM
SleekJag12's Avatar
Hello Zig,
A discussion about interpreting O2 sensor readings might not be a quick one!
However in a nutshell, the voltage readings from the sensors "switch" between zero and about 1.2 volts a few times every second.
Lean vs. rich is usually interpreted by the Long-Term Fuel Trim, which comes from data collected from the O2 sensors over time. In general, LTFT value in the negative range indicates rich running, while a value in the positive range indicates lean running.
Much debate usually ensues about the meaning of these readings and how they relate to the health and well-being of the engine.
My two AJ16s seem to settle into the range of -3.1 to -3.9, according to my generic scan tool.
Others here might provide more insight...
Old Sep 4, 2013 | 03:52 AM
Ziggy's Avatar
Originally Posted by SleekJag12
Hello Zig,
That'll do nicely! Thanks... Now I just need to work out how to get the LTFT out of my OBDII dongle - don't suppose you know the PIDs do you? It was looking at the STFTs that made me want to check the O2 sensors were doing what they should - seems they're probably ok.
Old Sep 8, 2013 | 11:33 AM
Ziggy's Avatar
Just getting my head round what it's doing - I'd be much happier if I had some carbs to balance, but hey!
STFT goes to zero at ~WOT. Why does it do that then?! I presume there's just a pre-determined map for those conditions?
Old Sep 8, 2013 | 02:23 PM
theJPster's Avatar
It's probably going open-loop. You can't trim the fuelling if you aren't listening to the lambda sensor so it makes sense for the ECU to report zero.
There is a PID for open/closed loop - at least, I can see it on my Scangauge II.
Edit: I use the PIDs from http://www.scangauge.com/support/x-g...-vpw-vehicles/
Old Sep 9, 2013 | 03:12 AM
Ziggy's Avatar
Edit: I use the PIDs from XGauges for ISO & VPW Vehicles : Linear Logic : Home of the ScanGauge
Yep, it is indeed... so assuming it's supposed to do that, why??
Thanks for the link!
Don B
General Tech Help
Nov 9, 2015 12:59 PM
jvitez
Oct 30, 2013 09:59 PM
Xeno
Mar 2, 2013 10:04 PM
Rikketick
General Tech Help
Feb 23, 2012 01:33 PM
