Looking for XJR6‘s Harmonic Balancer in the U.S.
Old May 26, 2020 | 01:23 PM
Parker 2's Avatar
The question on the Bosch 110 is if it has the needed margin above the original flow rate to satisfy this one setup
A different setup like a different engine would have its own variables of consideration
you can raise the flow rate only so much before you have to consider larger heat exchanger surface areas
Old May 28, 2020 | 12:16 AM
Jagboi64's Avatar
Originally Posted by Qvhk
I revisited Powerhouse’s web page about the XJR6 lower supercharger pulley and here is a picture of it here:
It seems like if I buy one it practically replaces two of the existing pulleys on the Harmonic Balancer which does not need much rebuilding?
You are correct, the Powerhouse pulley replaces two of the others. The pulleys don't need rebuilding, I'd take them off before sending a damper in for rebuilding. That will reduce your shipping cost considerably as well.
Removing the pulleys is simply removing the 4 bolts, very easy to do. Not even 5 min work. If you don't have the tools, a basic socket set will give you what you need, plus handy for other things.
Old May 28, 2020 | 12:21 AM
Jagboi64's Avatar
Upgrading the coolant pump is a well known thing, the standard pump is actually somewhat marginal. Even if you don't change the pulley, upgrading the pump is a good thing to do, especially in a hot climate.
Lightspeed
Mar 12, 2020 10:46 AM
cantork1
E type ( XK-E )
17
Apr 11, 2016 08:02 AM
