Misfiring to not starting
Old Oct 30, 2015 | 02:09 PM
Phil3814's Avatar
Default Misfiring to not starting
Hey folks,
I had a single cylinder misfire code (#6) so i decided to start with new plugs hoping it was that simple. Changed all the plugs, putting in Bosch Platinum 4's, now the car doesn't even start. I've rechecked to make sure each of the coils was seated properly and they were. So now I'm here for your thoughts. I'm guessing it's on to replacing the coils at this point. Also, in case you're wondering the engine codes I was getting were P0300, P0306, and P1314.
Old Oct 30, 2015 | 03:25 PM
Phil3814's Avatar
Since it didn't save my signature...I have a 1997 XJ6
Old Oct 30, 2015 | 07:44 PM
b1mcp's Avatar
Well first thing I would check is that Coils 5 and 6 are connected correctly (common mistake after plug change). They should be like this. Note 6 is different orientation to the others and normally has a yellow tape on the cable.
If they're ok, then check out Aholbro1's excellent collection of no start issues and solutions before you go replacing coils.
https://www.jaguarforums.com/forum/x...ngines-120221/
Old Oct 31, 2015 | 03:23 PM
Phil3814's Avatar
The coils are aligned correctly. I will check out the solutions on the above link. Thanks.
trulycar
Nov 3, 2015 09:45 PM
Adamjag
Oct 30, 2015 07:32 AM
djpxk8
Oct 26, 2015 01:32 PM
Type40
Oct 26, 2015 12:08 PM
Billwood
Oct 24, 2015 10:29 AM
