Mystery vacuum leak XJ6 X300 3.2
Old Jun 27, 2021 | 02:34 AM
Cameron24's Avatar
Default Mystery vacuum leak XJ6 X300 3.2
Hey gang, I have a vacuum leak after just having replaced the rear main seal even though I didn't touch any of the vacuum lines. I have been through cleaned the intake and sprayed some ignition start along the vacuum lines that I can access from the top to find the leak and had no luck . Any advice?
Old Jun 27, 2021 | 03:12 AM
Welcome to the Forums from across the ditch.
When you have a coffee break, please do an Intro in the New members Area, keeps the Boss happy.
Only thing I had on mine was the nylon line under the Inlet manifold that got moved a far bit to change the oil filter, but you could hear that sucker.
Maybe worth a good look, coz a lot of stuff would have got moved and shoved to do that seal.
Good luck.
Old Jun 27, 2021 | 05:08 AM
countyjag's Avatar
Going back a step, what has persuaded you that you have a vacuum leak? High idle?
Nedoerr
Jan 17, 2019 09:11 AM
joesoap
Jul 16, 2015 05:03 PM
2004jaguarxtype
Mar 3, 2015 06:30 AM
e21pilot
Apr 22, 2014 06:42 AM
RonaldP
Aug 1, 2013 11:17 AM
