Need help ASAP PLEASE
Old Nov 9, 2023 | 01:01 PM
Kray75's Avatar
Default Need help ASAP PLEASE
I have a 1996 XJ6 that is believed to be in anti theft mode. This had been after changing a fuel pump (which was not needed) and a fuel regulator. This has crippled me financially as I was also living in the vehicle at one point please help
God bless
Old Nov 9, 2023 | 05:37 PM
Welcome to the forums Kray75,
I've moved your question from General Tech Help to X300 forum. This is the place to post technical questions about your model.
Old Nov 9, 2023 | 07:40 PM
Parker 7's Avatar
There is a inertia / crash switch that can trip easily dropping out the fuel pump
It will always be on the car's right fwd of the right front door hinge
Following will be a pic for a right hand steering model with the gas pedal in the pic
This switch does not always reset so you can jumper the 2 white wires with a paper clip on the 3 wire connector
There is a fuse # 10 that controls the fuel pump relay and for this fuse to be powered the relay in the corner of the right heelboard fuse box must close on key rotation
You can swap the left engine bay fuse box relay for the righ heelboard fuse box relay
You can have the key in the run position with engine not started and the heelboard fuse box relay must click in your fingers on relay removal
The following pic will show the OBD 2 connector as this same fuse powers your OBD 2 reader
XJ6SIII
Dec 12, 2021 08:46 AM
Du'aine A Samuels
UK & Eire
Oct 22, 2015 01:25 PM
Ronan W
XJ40 ( XJ81 )
May 15, 2013 10:29 PM
EZDriver
Feb 20, 2013 07:12 PM
