Need Help Replacing 2 of 3 O2 sensors
Old Oct 29, 2015 | 02:28 PM
SD96XJ6L's Avatar
Default Need Help Replacing 2 of 3 O2 sensors
I have two new Bosch sensors arriving today. I need at least one to pass smog here in CA. I passed the sniff test, just not the check engine light.
Here are my codes:
P0158
P0138
I'm replacing the primary/upstream first.
Which one do you think on the downstream I should replace?
Old Oct 29, 2015 | 06:42 PM
sparkenzap's Avatar
The one with the lazy voltage cycles on your voltage trend. Don't have that? Then you have no real answer to your question. And, on the X-300, the downstream sensors control the fuel trim, not the upstream as on most cars.
Old Oct 30, 2015 | 10:15 AM
SD96XJ6L's Avatar
I realized there are four. I just ordered two more. Screw it. They are all OE with 116K on them. Out with the old in with the new...MPG!
jaguarxjl
Apr 21, 2025 08:18 AM
trulycar
Nov 3, 2015 09:45 PM
Chuck Schexnayder
Oct 30, 2015 11:55 AM
Sentinelist
Oct 29, 2015 08:07 AM
Johnken
Oct 28, 2015 11:21 AM
