Need some XJR parts
Old Aug 15, 2020 | 07:36 PM
icsamerica's Avatar
Default Need some XJR parts
Hey, I'm stuffing an AJ16SC in a 1976 XJ coupe and need a few parts. Any help would be appreciated. If anyone has please post up or message me contact info.
1. Lower super charger pulley
2. AC Compressor
3. Super charger tensioner
4. Engine control module
5. Mass ir flow sensor
6. Complete throttle assembly with cresent shapped turn up.
7. Motor plate for a 4L80e
Old Aug 15, 2020 | 09:37 PM
Jagboi64's Avatar
1.For the lower pulley, you might consider getting the uprated pulley from Powerhouse in the UK.
2. AC compressor is the same as any X300 - Rockauto.com is a good price.
3.The tensioner pulley is nothing special, you can match it up to other pullies. I changed mine to a metal one instead of plastic, as they use the common 17mm bearing diameter as GM and Ford pullies.
4. Try car-part.com for used ones. Be aware that the 1995 XJR does not have EGR, 96 and 97 do, so different ECU's
5. Can't help with the rest, sorry. If it helps, the 4L80E bolt pattern is the same as the 6.0 V12.
Old Aug 15, 2020 | 11:05 PM
Parker 2's Avatar
Mass air flow sensor and ECU are specific part #s to the SC engine
A/ C compressor is a Denso 10PA - 15 or 17
See video on how to refurbish on their website
https://www.shopcenturyautoair.com/store/c1/Featured_Products.html
Old Aug 19, 2020 | 09:33 PM
icsamerica's Avatar
Bump, still looking for these parts,
I need the complete tensioner assembly for the super charger.
Old Aug 20, 2020 | 10:18 AM
Robert Laughton's Avatar
Hi....John?
I bought a S3 XJ steering rack from you a few years back. I'm in Ontario.
I'm part 3 XJR6's.
I have the tensioner shown. I'll locate the other bolts. I'll accept whatever you thunk's fair.
Give the address and I'll send.
Call if you like 905-932-0284 Rob
Old Aug 20, 2020 | 09:59 PM
icsamerica's Avatar
Originally Posted by Robert Laughton
Hi....John?
I'm part 3 XJR6's.
Thanks, you're da best! I'll reach out.
Old Aug 21, 2020 | 08:57 AM
Larry Louton's Avatar
I have a airflow meter for a 1995 4.0 Jaguar XJR. $200.00. No warranty implied or given. Accepts PayPal. Plus shipping.
Thank you.
Larry Louton
Cjizzle711
May 21, 2020 07:27 PM
beady
Jul 14, 2015 06:28 PM
srhodes87
Nov 11, 2014 05:46 PM
benebob
Feb 6, 2011 05:00 PM
Baumkun
Jul 27, 2007 07:09 PM
