No crank, check engine light goes out, no SLCM function at all.
Hi I’m new to Jaguar x300 ownership. I got the car (1995 x300 auto) as a non runner. I’ve been trying to do some checks with the information from a few other threads. The car has been sat outside for 3-4 years and I don’t have any history of what went on with the car. The problems I’ve identified so far:- Check engine light comes on and then goes off before cranking. None of the SLCM functions seem to work, central locking, key fobs, boot release, fuel filler flap, door locking button on dash at all. The car is immobilised and not sure why.
I’ve taken out the SLCM and ECM. SLCM has wet connections, so I’ve dried these and taken the module apart and cleaned. All pins and connections look good. I’ve done the same with the ECM but still no change.
I did notice one of the SLCM connectors has what looks to be 2 wires joined together with a non factory connector. I’m not sure if this is correct or not? The wires are I think the ‘RF input’ and ‘RF ground’. Could this be causing me a problem with starting the car?
Your starter circuit is a little bit different then the the more common 4.0 liter version that has a different transmission , ZF4HP24 with a transmission mounted rotary switch
Your ZF4HP22 does not have this
This is a pic of he 24 that is close but they both have the SLCM enable
Thanks for your replies Parker. I have checked that fuses and relays etc are all in where they should be have not blown. My main concern are the wires that are linked together on one of the SLCM connectors. Is this how it should be or has someone else done this to overcome something in the past??
Those wires on the slcm do not look factory but they infact are factory.
They are the wires for the remote antenna.
it obviously runs a coax cable (negative shielded around the outside of the positive) but the positive and negative need to be seperated to connect to the slcm
If you turn on the stereo the antenna extend wire will be provided a ground
The antenna extrend moter will have power so check for power first
Take a pic of the connector wires colors and can refence against the wiring guide the wires to where
But you have multiple wires on the orange connector
Researching and will be back
If you want to see the starter rotate you can remove the large starter solenoid relay and jumper between sockets 3 and 5 with a blade type connectors on your medum gauge jumper wire
Pic coming
Thanks that makes sense now. I’m glad I didn’t start taking it apart! At least I know that it is factory.
I will continue testing things. I’m convinced that due to the amount of water/moisture in the car that is playing havoc with shorting something that is hot all the time to ground and therefore turning the check engine light off.
If I wanted to just prove if the engine will turn over, could I put a 12v feed direct from the battery to the starter relay and then use a jumper wire? Would this work if the immobiliser is still preventing a crank with the key?
A common thing is a blocked water drain line in the fuel cap filler well that allows water to migrate into the SLCM connectors
The socket X will provide your 12 volts from fuse Z to engage your starter solenoid and starter motor
This would bypass your immobilizer system
I’m sure this is what’s happened. When I removed the boot liners to access the SLCM I manually opened the fuel filler flap and its was full of dirt and leaves etc.
If I do this work around I still won’t be able to get it start as there won’t be any power getting to the fuel pump and other ignition parts will there?
Pic coming
not sure what that orange connector is.
i noticed it is in my car not connected to anything either
was thinking maybe it was something like the optional inclination sensor or something? I dunno.
but certainly not required for anything.
Unfortunately, this is a bit of a theme where cars have been off the road for a long time. There have been a number of similar threads over the years. Most people give up and never resolve the issue (or never tell the forum anyway) so it's only hearsay.
Here is one thread where the owner did persevere. Sound familiar?
