No green lights at night =(
Old Jan 17, 2015 | 12:14 AM
prince_kuja's Avatar
Default No green lights at night =(
Hello everyone! I have a question about the lighting in the car.
The lights on the sunroof control, the door panels (the window switch) on both sides, the center panel (the radio/clock/AC temp display stays on)..every once in a while the green lights will stay on, nice and green all over, however they don't stay on for long. They blink on and off here and there but mainly everything is off.
My friend says its a fuse, im hoping so also. If this is a fuse, where is this fuse located? The main panel is fine, no blinking at all.
The AC/Heater works fine, however when its time to turn it in its just hard to see what buttons im pushing.
The radio turns on, its just the green lighting that goes on and off. Any ideas??
I provided a pic of the cars interior (not mine) and circled to better explain what im talkin about.
idk if this is related to the above issue but:
i have to keep playing with the switch to keep the headlights on (they have a bit of a hard time staying on initially but they do stay on once they are on, no flickering while driving.)
Is this also a fuse? maybe a contact issue?
Thank you!
Attached Thumbnails No green lights at night =(-733a489a-8213-4d8f-a0ac-57d9b32858e7_23.jpg
Old Jan 18, 2015 | 09:11 PM
aholbro1's Avatar
See post #5.
https://www.jaguarforums.com/forum/x...witches-53109/
If that doesn't work, search the TSB's in the stickies or do a search on Motorcarman's posts. I recall he posted a TSB on correcting this issue that had all the things to check.... more than just the ground I found
Old Jan 20, 2015 | 09:35 PM
Thank you very much!!
Im looking now, but i don't see anything relating to my issue in the TSB (unless its labeled under something i don't know/or ow;dint call it?)
I don't know what the issue could be labeled as, what would you call it?
Old Jan 23, 2015 | 05:49 AM
aholbro1's Avatar
I think "illumination" was in there. I saw the TSB in a Motorcarman post; just assumed it is in the stickies, but it mayn't be.
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
Jpav27
Jul 31, 2022 06:43 AM
redrover41
23
Sep 25, 2015 01:33 PM
avern1
Sep 8, 2015 06:25 PM
